Summa F1612 routing mat
Ldireprophil
PHILJOHNSON
Sales Manager
That would have been good information to include in the original post. I have had some users use packing foam as an alternative to the milling mat, but that can be a little inconsistent compared to the milling mat. Also, it looks like you are cutting pretty deeply into the mat and you might be able to get more usage out of each mat and also use the other side of the mat if you didn't cut almost all the way through.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext 112
[email protected]
Ldireprophil
Best regards,
Phil Johnson
Airmark Corporation
philj@airmark.The mat exactly what it was designed for, it takes the damage...not a scratch on the moving
Sutherland Felt sells a blue mat material that is awesome and significantly less than own mats.
This is an answer I am looking for, thank you.
Flatbed Tools
What's a good replacement for the rolled foam cutting mat? What are you using and where to get? TIA View attachment 154492
What is it that you're routing? Also, we have many different options for different purposes (including different sizes and price conscious). We have oem foam, sticky foam (for small parts), regular conveyor belt material and cost conscious purchases. Do you have an email address or phone number to call to discuss and narrow down what you would like!?
Sent from my SM-G950U using Tapatalk
Ldireprophil
ACM, acrylic, PVC, MDO all in various thickness, and of course your blade cut usuals like vinyl, coro, magnet, canvas, perf, etc.
