Summa - multiple unique cuts
Saturn
Your Ad Here!
When I do "sticker sheets" it's the one time I use FlexCut. Typically this works great because the outer perimeter for most sticker sheets are plain rectangles. However, if I want to do something with a more complex outer shape, it (FlexCut) behaves as though the 'Sorting Vectors' are set to 'Directional.' Which means a sticker that would normally take just 3-4 seconds to cut if it were a single cut, now takes 10x times longer.
I know I can go into the RIP (Onyx in my case) and set up even more cuts, but I would have to set the pressure at the time I generate the file, and would lose the ability to adjust the two, independently at the cutter.
Am I overlooking something? I use Onyx to print the art and generate a cut file that I grab in SummaCutterControl. Would GoSign or something else allow me to adjust the pressure of KissCut1 and KissCut2 after the file has already been made? As far as I can tell, you can only adjust a single "regular" cut and a single FlexCut at the cutter. If you want more than that, you're forced to set cut pressures ahead of time in the RIP, overriding the cutter.
Would love for someone to pop in and say, "Oh just go into the registers on the Summa and switch this setting from X to Y and it won't do FlexCut Directional." I suspect I'm just SOL, but thought after all these years I'd just ask... ;p
TL;DR - How do you guys do the attached sticker on a Summa roll cutter? Regular Cut + FlexCut? Or override cutter settings and lock in the pressure for two different cuts when you RIP?
balstestrat
Problem Solver
Why do you use cutter control to cut?
Just use cutserver directly and you can change the pressure as you wish.
  • Agree
Reactions: 1 user
Saturn
Your Ad Here!
Well jeepers. Old habits die hard is all I can say. This is why I asked!
Onyx was not playing nice with Summa when I got my printer, and I always assumed it was best to make changes at the cutter when possible, but if Onyx cutserver is stable and will let me adjust multiple non-flexcut cuts on the fly... that sounds like my answer. Thanks balstestrat. I'm sure it was obvious to everyone but me.
Can anyone speak to the downsides of using Onyx cutserver instead of summacuttercontrol? Will it let you plug in 2 or more cutters at once without $$$ upgrades? I'll be looking into it this week regardless.
balstestrat
Problem Solver
I don't think of any downsides unless you happen to be on a version with a bug but that's not the assumption.
No limits on cutters and you can turn on the Roll server to have barcodes working from the cutter.
Jetpack Stickers & Labels
We always control from the RIP. Most we ever use is 3 different Contour Cuts. For the sticker in your image, we'd cut all the kiss cuts first, then the hang holes, then the perimeter cuts. No flex cut. It's too slow.
  • Agree
Reactions: 1 user
