Saturn
Your Ad Here!
When I do "sticker sheets" it's the one time I use FlexCut. Typically this works great because the outer perimeter for most sticker sheets are plain rectangles. However, if I want to do something with a more complex outer shape, it (FlexCut) behaves as though the 'Sorting Vectors' are set to 'Directional.' Which means a sticker that would normally take just 3-4 seconds to cut if it were a single cut, now takes 10x times longer.
I know I can go into the RIP (Onyx in my case) and set up even more cuts, but I would have to set the pressure at the time I generate the file, and would lose the ability to adjust the two, independently at the cutter.
Am I overlooking something? I use Onyx to print the art and generate a cut file that I grab in SummaCutterControl. Would GoSign or something else allow me to adjust the pressure of KissCut1 and KissCut2 after the file has already been made? As far as I can tell, you can only adjust a single "regular" cut and a single FlexCut at the cutter. If you want more than that, you're forced to set cut pressures ahead of time in the RIP, overriding the cutter.
Would love for someone to pop in and say, "Oh just go into the registers on the Summa and switch this setting from X to Y and it won't do FlexCut Directional." I suspect I'm just SOL, but thought after all these years I'd just ask... ;p
TL;DR - How do you guys do the attached sticker on a Summa roll cutter? Regular Cut + FlexCut? Or override cutter settings and lock in the pressure for two different cuts when you RIP?
