Need Help Summa not cutting copies
bsipsy
I'm having trouble with a Summa S2 T-160. When sending multiple copies of a job (one panel of a 2 panel job), no matter how many copies I select in Flexi, it only cuts one copy then advances to the new origin as if it's done. Anyone experienced this issue before? Not sure if this is a Summa problem or a Flexi problem.
jerry369
Are these OPOS jobs or just cutting? On the S2 series plotters, sheet mode is enabled only for OPOS jobs. Only with the introduction of the S3 series is sheet mode also enabled for cut-only jobs
bsipsy
These are just cutting. Solid material with cuts sent from Flexi. We are cutting from a roll of material, and need the cutter to just cut copies of the same piece across the width of the material. Everything in Flexi looks correct. However, when sending the cut, it seems as though it's just ignoring all copies past the first one.
jerry369
After cutting the first copy with Flexi, go to: Actions->Replot and enter the number of copies you want to cut. This will cut the next row, filling the entire width of the material. When there is no more space for another copy, it moves on to the next row and so on. You can set the distance between copies in: Settings->General->Recut offset.
