Summa S one d140 fx contour cutting
msenjur
yeah... that is whole new (old actually) way of printing as im used to! We set up files like this in the past, where you have to draw squares around graphic and export two files, one for print and one for cutter... This way is a lot more complicated than import file to onyxRip and print multiple copies or files at once.
PHILJOHNSON
Sales Manager
You can create your own cut file with registration marks using Illustrator or Corel before you RIP and print using Onyx. The SummaCut FX machines are not intended for use with GoSign, so using the direct import action set will probably not work well, but you could potentially use Winplot and Cutter Control to transmit the Onyx cut files.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext. 112
philj@airmark.com
balstestrat
Problem Solver
Best regards,
Phil Johnson
Airmark Corporation
philj@airmark.com
It's S One FX according to him.
olegiy
If ONYX Cur Server is not working properly, why not use the server built into Summa Cutter Control?
There is also a license-free ColorGate Cut Server.
msenjur
yeah... i did at the end. and i cut it in several segments so i solved it.
in the future, i will print smaller segments.
