Summa S2 T160 always cutting FlexCut
carlroger
Hi!
Our Summa S2 T160 suddently started cutting everything as FlexCut. We haven't changed anything in our setup, and the Summa hasn't been reconfigured in any way. But still, everything is cut with 15 mm flexcut. This is extremely annoying and why does it do this all of a sudden?
We use Caldera as RIP.
Any ideas?
/Carl
PHILJOHNSON
Sales Manager
HI Carl,
I would check and make sure you don't have flex cut mode turned on. If that is turned on the cutter will flex cut everything in the job even if you have the file setup to do both a kiss cut and a flex cut. You can turn flex cut mode off in either Summa Cutter Control or on the onboard menu on the cutter.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext 112
[email protected]
carlroger
HI Carl,
Best regards,
Phil Johnson
Airmark Corporation
[email protected]
I've been through the settings several times, and the flex cut mode is not turned on. I'm totally lost :confused:
lennybennett
Hi I know this an old post but did you resolve it? im having exactly the same problem. 2 different onyx rips and summa cutter control all flex cutting even when its not activated. I have updated firmware been through every setting on the machine and software and still no better off. i had a engineer on teamviewer yesterday and he didnt know what was wrong with it. he even said it might just be broke?
FrankW
Check your software settings too, not the cutter settings only. The layer settings in the cut server in onyx?
