gabagoo
I have only had this cutter for a few months, so I am on a learning curve. I generally only use this plotter for printed items that need cutting. I know with this blade you really should only have it out enough to cut through the vinyl and then use pressure to give it more cutting power. When the blade was new, to cut through a 3ml with a 3ml laminate I only used a pressure of about 90 - 110. A month or so later I now am at about 190 and sometimes that does not seem to be enough. Just curious from others what sort of cutting pressure are you using so I get a gauge of where I should be. With my other cutters I generally do not see such a drastic swing in pressure changes over such a short period of time.
Also on a side note I am curious as to the test cut the Summa does. What am I actually supposed to learn from the little square within the square. I generally just test the outside square to see how it weeds but not sure what the inner cuts are for?
