Summa S3 Issues
sleepygstickers
Hey Everyone,
I just got a Summa S3 TC160 and i cannot figure out how to stop it from creating these tabs. I have tried everything I can find to no success. I've got it down to where its minimal but the cuts are rough along the edges. Im using Onyx Go, 60 degree blade, Substance Vinyl with Substance Laminate, and flex cut is the setting. Any help would be greatly appreciated. I' IMG_5895.jpeg ve attached a photo for reference.
balstestrat
Problem Solver
If you are using flexcut it will create tabs.
But as you just got it I would contact the seller and let them show how to set it up correctly.
balstestrat
Problem Solver
No and I think you have some other issue there. Possibly with your cutline in the design.
You really have to go trough the whole process in order. Calibrate your knife (you are not using the default knife). Test with a sample file. Try without flexcut. Try with default flexcut settings. etc.
sleepygstickers
Ok sounds good, thank you!
