Hi, new to the forum, hoping someone might be able to provide some insight into my problem.
I recently purchased a used summacut d75r, and was assured that it had low hours and was working properly. It was demo'd using 15" wide vinyl, however I've been having trouble with 24" and 30" rolls.
If the left hand pinch roller is in the sweet spot 2nd from the right, the machine errors telling me to reset the pinch roller ("the left pinch roller is not set properly"). However, if I nudge it a couple of mm out of the sweet spot to the left, it will register. That kind of solved the 24" problem.
But, if I want to load 30" media, the cutting head will not travel past the 2nd pinch roller spot from the right, so the machine won't allow me to cut anything over 24" wide.
Ok, so i just started it up, and now noticed that when the LCD boots up is says D60, not D75!? Although it's clearly a D75....eeesh.
Any feedback would be greatly appreciated.
