We've always bought ours from SpeedPress.
Rhino Cutting Mat SpeedPress Sign Supply
The Best Deals on Sign Supplies. The super size, self-healing mat is perfect for your production tables. Now you can cut razor straight on this thick, seamless mat.<br> Make a cut, then another cut a hair away, mat doesn’t gouge so every cut is flawlessly straight. Sizes from 2’ to 4’ up to 6’ x...www.speedpress.com
If I can get those sort of prices right-pond, then I'll step away from my innexpensive HDPE sheets - they're getting tired and clipping blade tips too much these days.Lots of brands and places that sell them, Rhino is the most common, but they're all just a sheet of urethane.
I get ours through USCutter, reasonable cost , lot of sizes, if they don't have an exact size, just get one a bit bigger and trim it down.
Image One Impact Table Top Extreme Cutting Mat - 24" to 144" Sizes Available
Tabletop Cutting Mat, assorted sizes. Constructed from 6mm virgin seamless polyurethane which means your blades will last longer as you need less pressure to cut through, and you get MUCH smoother cuts when trimming.uscutter.com
