texture surface
WOODBS
we have a possible job to install the textured surface material. what are you guys getting psf? is it worthe getting the 3m tool that holds teh heat gun or just use the hand held tool with heat gun in other, and is the digital gun necessary? thanks brett
cgsigns_jamie
It's the new 3M IJ8624
I saw a demo at the 2008 ISA show and it's amazing stuff. It's a printable plastic material that you "melt" onto a rough surface.
I have not used it yet so I don't have any info on pricing.
R08
Sounds cool... I'd love to see that.
3M™ Scotchcal™ Graphic Film for Textured Surfaces IJ8624
Two-mil removable graphic films designed for solvent piezo inkjet or electrostatic printing. When heated and applied with 3M's application tools and techniques, the film conforms to moderately textured surfaces, both flat and curved, including concrete block, brick, industrial stucco and tile like surfaces commonly found in arenas, stadiums, restaurants, retail and other public venues.
3M info
cdiesel
Minimum $4/psf on install only.. and that's with a lot of volume. You're only going to get 25-35 sq ft per hour installed if you're doing it correctly.
The tool is NOT the rolle-pro. That's for doing rivets and similar contours. You'll need TSA-1, TSA-2, TSA-3 (and maybe TSA-4). TSA-4 is the one that holds the gun and has two handles, aka the rocker-n-roller.
Also, don't cheap out on the heat gun. Get the good one from Steinel. The last job we did with 8624 we picked up after another installer couldn't get the stuff to stick. Found out later they were using a regular heat gun, and we had no problem with our Steinels.
Brett--I'll lend you our tools if you'd like.
