Checkers
Although I commented about this in this topic, I feel this deserves a topic of its own.
Signs are advertising!
Here are some notes I wrote to myself , several years ago, about pricing. The same basic principals still apply, although, the methods of calculating the information has changed some.
On-premise signage -
Advertising costs are based on an advertising industry standard of cost per thousand or CPM (cost per thousand). In simple terms, an advertising outlet, such as a TV station, radio station, newspaper or magazine will charge you XX dollars to advertise or promote your business to 1000 potential consumers.
According to statistics available through the Outdoor Advertising Association of America, the average CPM for advertising in a top 100 market here in the USA is $15.14. In other words, if a magazine boasts a circulation of 60,000 per issue and their CPM is $15, your cost for an ad probably will be $900.
So, if you contact your department of transportation, you should be able to get traffic counts (the number of vehicles that travel a road on a given day) on the road where the sign is to be placed. From there you will be able to determine the worth of a sign.
If local regulations permit, you want to start by properly locating and installing a double sided, illuminated pylon sign for maximum visibility. Now you can safely assume that the all the vehicles that are passing your location will see your sign. The next step is to look at the traffic counts for the road on which the sign is placed. If the location you choose for your sign has a traffic count of 5,000 cars per day, you can safely assume that your sign will make at least 5,000 impressions per day. And the “M” in CPM is 5 per day, for every day that sign is functioning.
I’ll say that a typical pylon sign, when properly maintained, should last about10 years, or 3650 days. If you multiply $15.14 (the average cost of traditional advertising) x 5 (the CPM per day) x 3650 (the number of days the sign should last), you’ll come up with a total of more than $275,000 for the advertising value of that sign.
Realistically, a typical pylon sign could cost anywhere from $10,000 to $25,000, maybe more depending on the location, size of the sign and the complexity of the design. Over its lifespan, you can expect to spend up to 50% of the original cost of the sign in operation and maintenance. Once again, this depends on the size and complexity. So, if you invest $25,000 in your sign and another $12,500 maintaining it over the next 10 years, you total expense for exposing your business to 18,250,000 potential buyers will be $37,500 as compared to $276,305 using other forms of media.
Vehicle lettering -
When I worked for a franchise sign shop, we referred to a survey (I forget who did it, maybe Texas DOT?) in which a typical delivery truck, traveling 25,000 miles per year in a major metropolitan area, would make about 2.2 million impressions in that time period.
I live in Harrisburg, which is not a major market. However, I did some unscientific counts while commuting back and forth to my old job. During Rush hour, I would pass an average of 65 cars per mile. I'll let you do the rest of the math there
If you consider that vehicle lettering or graphics should last a minimum of 3 to 5 years, that vehicle will expose the client's business to a minimum of 6.6 million people. Using the above formula on a $5,000 van lettering job, the CPM would be about 75¢.
There are many advantages to vehicle lettering too, when you compare it to other forms of advertising. In this day and age, the most obvious is it's difficult to be ignored. You can't change the station or fast forward through the advertisement to get back to the show. Plus, it promotes your business to the market you already serve. Also, don't forget that every form of advertising needs to be repetitive to be effective. So, as long as you're out there driving your vehicle, your advertising message is being seen.
Here are some links that I would consider required reading...
www.oaaa.org
http://www.sbaonline.sba.gov/library/pubs.html#mt-12
http://www.signs.org/SignIndustry/content.cfm?ItemNumber=1665&snItemNumber=1667&token=23244&userID=
Here's one last thought...
The cost of a 30 second spot for the 2006 Super bowl was just under 2.5 million dollars. That’s about a $28 CPM.
Checkers
Vehicle lettering -
www.oaaa.org
Checkers
