The VP models come and gone, why?
34Ford
Can anyone tell me when the VP models came out, and when did it stop?
The SP models been out longer, right?
I know where a VP540 is for 10k but before I call him I was wondering what happened to the VP's?
Do you feel they were a good reason to stop building them or should Roland kept them going?
Jim Hill
I am not sure about the VP models but my old SP-300 works like a charm everyday.
After two years of service I had to start changing some parts like the cap tops, wipers, scrapper and a few other items but other then that the printer is really a fantastic printer.
Jim
34Ford
I finally found a bit of history on the VP models and they were apparently high performance printers for a few years.
Now I see the SPi models are using the VP plastic cases.
Finding used SP or VP here in N.C. is not to good. Most are 300 to 500 miles away.
http://www.rolanddg.com/news/index.html
Hamamatsu, Japan, April 3, 2007 – Roland DG Corporation today added two new high-performance models to its best-selling VersaCAMM ECO-SOL MAX inkjet printer/cutter line – the 30" VP-300 and 54" VP-540.
Hamamatsu, Japan. January 7, 2005. Roland DG Corporation, the industry leader in integrated print/cut technology, today introduced the VersaCAMM SP-300V, a 4-color, 30-inch-wide ECO-SOL INK printer/cutter for both outdoor & indoor applications. Designed for easy operation, the SP-300V builds on VersaCAMM innovation with the addition of Roland VersaWorks™, Roland's own powerful color management software RIP.
Hamamatsu, Japan. September 1, 2004. Roland DG Corporation today introduced the VersaCAMM SP-540V, a 4-color, 54" wide ECO-SOL INK printer/cutter.
Gene@mpls
We started with a SP-300 and it is a great printer- we had trouble mostly
with the encoder strip and its reader. We then bought a VP-540 and it has
been bulletproof for 4 years. We print a lot for a sign shop (I think) and do
no printing for anyone else. I have only changed the wipers and cap tops-
and only because I thought it might be time- not to fix a problem. The SPs
were (not sure about now) 2 head printers and the VPs are 4 head- hence
the greater performance. Should also mention that neither printer ever
tasted Roland ink- only Triangle since new- and I removed the flip up
cover on the VP from day one- and have never even cleaned the encoder
strip on this one. Print test still looks like it did on day one. Gene
