this one needs help...
keptquiet
i need some help on this one. any ideas on what it needs????
i attached the corel file created in outlines and a zip of the current and proposed logo that definately needs something.
hes asking about a tree added to it????
  • Guthrie Tree Service.zip
Fred Weiss
Here's the image so all can see
Colin
Tree & Lawn
The one on the bottom has real potential. I would move the Guthries up a little so it doesn't crowd the text below, and have "SERVICE" without the reverse panel (the reverse panel makes it too loud). I would then increase the spacing between the letters in service a little more.
Colin
iSign
put a down-pointing triangle behind it... not equalateral but a wider-then-tall one... maybe a mint green with forest green border & subtle thin vertical stripes.
Keep the reverse panel but maybe forest green with white letters.
I like Guthries close to the L & G... but add some color, maybe pick up the mint green again & re-use the forest green outline, or black... plus a littl white pinline around that to set it off the triangular panel??
ApexSpeed
Just a suggestion, I think the italic chisel font on the bottom fights heavily as a bowed piece of artwork (flows in WAY too many different directions, it distracts the eye movement pattern), with the very diagonal script. I think you would see a quick and drastic improvement if the typeface was a "regular" or non slanted face with the arc, combined with the diagonal script.
Also, you may want to increase the size of the TREE & LAWN so that there is a definite difference in levels of information, though try to keep it from getting too stretched and distorted (it's already getting too far from the original face proportions).
It's a great start, and not too much is needed to be a really striking piece.
Cheers,
doug
mrsticker
Very nice...What's the name of the font used for the word "guthries" and where available, if you dont mind me asking...I love looking at other peoples work...it hels a bunch to get the juices flowing and be more creative
