Hi All,
I have a 60” HP Z-series aqueous printer that I currently use to make indoor posters on matte Litho paper.
I now have an opportunity to provide tradeshow popup panels to a local company on a somewhat regular basis (at least once a month). The company I’ll do this for has a few different brands of 10’ popup frames, but they all follow the same graphic mounting standard. They all have the plastic trim strips at top and bottom and magnet-apply to channels that fit on their frames.
I’m attempting to compile a budget-friendly list of items that I will need to purchase to make this opportunity happen, and I was hoping you could help with some questions.
Here is what I think I need, with my questions:
Laminate and printing substrate
60” laminator
Black Trim strip plastic
120” rotary cutter
Poly bag material
1/2" magnet rolls
Anything that I'm missing? Any other advice (like 'you're crazy'... 'don't do it' ... 'you have no idea what you're getting into'...
Thanks for all your help.
John
- I was thinking that I would call lexjet and go with their recommendation, but I’m curious on your thoughts. I believe total thickness (substrate plus laminate) is critical for the rigidity of the panels, but I don’t know what this thickness is. I also want to make sure the laminate is optically clear satin and can be used with a cold laminator. Thoughts?
60” laminator
- Do I need heat-assist for what I plan to do?
- Do you know what material these are made of? I have a 3’x4’ laser cutter that I would love to use, but I know that some plastics are very toxic when laser cut. I don’t currently have access to a CNC router.
120” rotary cutter
- I’m assuming that a keencut will work for what I need to do, but I’m open to suggestions.
Poly bag material
- I've seen that their panels pack into nicely fitting individual bags. I'll be looking for a sources for poly rolls and some type of low production heat seaming... something or other. Any ideas?
1/2" magnet rolls
- Looking for a source for rolls of magnet. I think some of the better popup manufacturers have attracting magnets that snap the panels perfectly into place. I think it is known as 'grooved' magnet, but I'm not quite sure.
John
