Tree Vector
Anyone know where I can find this tree as a vector.. i really don't want to have to recreate it
Old Timer
There is a free software program to download called inkscape. once installed you can open the jpeg, trace bitmap, save as .eps, open in Illustrator and you have your vector. Some good results, some need clean up
The Vector Doctor
Chief Bezier Manipulator
No autotrace program out there will produce anything good from this. You need some human to work on it. On a job like this I would use the pencil tool instead of the pen tool in illustrator and go along the edges of the leaves and trace it wobbly to try and replicate the look of tree details. Like what I did here real quick as an example. A tablet is perfect for this type of work
Thank you so much! That's great advice
JimmyG
...... On a job like this I would use the pencil tool instead of the pen tool in illustrator and go along the edges of the leaves and trace it wobbly to try and replicate the look of tree details. Like what I did here real quick as an example.
.....A tablet is perfect for this type of work
What brand of tablet and model # do you use or can recommend?
The Vector Doctor
I have only used Wacom. The one I have is an old Intuos 3 that is been very reliable for over 10 years. I have read the newer ones have a rougher surface that wears down nibs quickly. There are other cheaper tablets but I have never used them to comment
JimmyG
Thanks Doctor...I have the wacom intuos pro large that I recently got with a corel draw bundle but haven't tried it yet with anything like what you illustrate above...Methinks maybe I should.
I was wondering if you had one with a touch screen and just wondering the screen tablet are easier to use.....
The Vector Doctor
If you've never used one before don't give up on it. Anyone that has spent most of their life using a mouse will dislike a tablet at first but once you get accustomed to it you will never want to use a mouse and your wrists will feel better in the long run
jfiscus
Rap Master
Definitely Wacom, I've tried the cheaper larger ones and they're just too glitchy. Went back to Wacom.
