UCJV 300 - How to use as cut only since print function cannot be repaired
Kari-AG
Hi,
Our Mimaki UCJV300 printer has major issues with the print function and the repair is just too expensive. We would like to continue using just the cut function until we come up with another solution.
How can we do that since we get errors from the print side. We are using Rasterlink as the Rip.
In desperate need of help because we have two big cut vinyl jobs we need to get produced ASAP.
Kari - Alphagraphics Dallas
What error are you getting on the print side? It all depends on if that is a fatal error or more of a warning.
Kari-AG
Raster link sends the cut file and creates the path - It then indicates it is waiting to cut. On the Mimaki panel it is giving us Error 625 reinsert cartridge and 627 no ink errors.
We have replaced the overflow sip tanks and the valve that circulates the ink. the Cyan print has failed now. if we put any ink in and it attempts to print it just makes a huge mess. Given the age of the printer, we just want to be able to turn off all print functions so it only cuts. Can we do this so it does not see the issue with the ink an print heads?
Unfortunately, no. The machine needs to see that the ink system is running properly or it will just keep erroring out. Theoretically you could buy ink chips or find permanent chips that you could install in the printer and it would see that inks are installed. Then you could fill the tanks with water or rig the magnetic sensors that read the levels. That would get you passed the print errors and then would be able to cut all you want. But there is no easy way to do it.
Smoke_Jaguar
For the sheer effort involved, might as well pick up one of the CG-AR series cutters and have something that is faster at cutting and not going on the verge of breaking constantly.
What issues are you having? I am based in OKC, so I do lots of work in Dallas. I get a lot of machines that dealers say are too expensive to fix and they're typically pretty easy. The UCJV300 series is also a specialty of mine, and I actually really like working on them.
Kari-AG
We are looking at a cut only machine now given the repair cost and as we just installed a Canon Colorado. Do you have recommendations?
Smoke_Jaguar
I'll leave the company nameless, as it might've just been the tech themself who was incompetent, ignorant or just didn't want to work on the machine. They service the Dallas/Ft Worth/Austin area, and I looked at 2 UCJV300s they were told were beyond repair. The issue was ink overflow codes. 4 $30 valves later, and problem solved.
I suck at keeping secrets.
It's because all techs are self taught so you get a large spectrum of abilities. The manufacturer training basically teaches you how to install a new machine, not fix it. There's also no prequalification. I was a manager of a Papa Johns before becoming a tech. That's why one dealer might have a tech who says, "You need a new printhead and main board" for every issue that pops up. Or, "That's beyond repair" when in reality they mean, "I can't diagnose it." or they simply just want you to buy another printer. Works out for us though. More people are fixing their own printers these days, even though the manufacturers keep making it harder to do.
Smoke_Jaguar
Yup, I do a LOT of second opinions, as do other techs. If someone describes the issue, I describe what I think the solution and the costs are based on the info at hand. If they significantly diverge, then something's up. One of these days I might go all fancy and charge for it.
