Need Help UCJV300-160 - SYSTEM HALT (1) 1c3 SLDR2H
Neotype
Hi everyone,
I recently picked up a Mimaki UCJV300-160 and could use some help tracking down this error:
I inspected and powered on the machine before buying it, and it wasn’t showing this error. It only started appearing after I moved it.
So far, I’ve:
  • Checked the cables running through the drag chain for continuity. All tested OK.
  • Checked the ribbon cables between the G5HDC PCB and HDC RL PCB.
  • Unplugged and reseated all cables connecting the main board and carriage board.
  • Tested the printhead cables for continuity.
  • Checked all fuses on both the carriage board and main board.
  • Followed section 7.2.1 of the maintenance manual to check the printhead and G5HDC PCB for damage. The resistance readings and fuses all checked out.
  • Im getting power in the Carriage board as i can see the LEDs light up there,
I also tried disconnecting cables and removing fuses from the head board to see whether it would report different errors, but the error stayed the same. This makes me wonder whether the main board is receiving any information from the head board, although I haven’t confirmed that.
Removing fuses from the main board does change the error codes. That suggests it’s detecting at least some faults, but I realise it doesn’t necessarily rule out a main board issue.
Has anyone dealt with this error before? Could something have been disturbed during transport.
Any guidance on what to check next would be appreciated. Thanks!
Unfortunately, if the fuses are all good and cables test good, you just have to replace the slider board. One of the chips that handles the head signal fried basically. I'm sure there's ways to fix the component that fried but that's out of my wheelhouse.
Smoke_Jaguar
Overseas, so I am not going to offer to fix it. Last time I sent something to Australia, it took over a month and was $40 to send a few grams of parts.
Neotype
Yepppppp, i have well borked it, was doing board level diagnostics and was testing serial data from the HDC cable was gettting good data out of the main board,
THEN, i plugged the HDC cable directly to the Carriage board instead of the COM board, (they had to have the exact connectors :doh:)
Effed around too much and found out the expensive way, :banghead:
The 2 Gen 5 heads have been preserved now so i guess ill be hunting for another UCJV in the marketplace
Smoke_Jaguar
This is why I ask people to give me codes before unplugging stuff and mussing around under the hood. Happy to provide guidance, but far to easy to bork things. Never unplug more than 1 connector at a time when troubleshooting. When swapping boards, religious use of photos, paint pens and cable tags is vital. These aren't designed for DIY, so a mistake can be punishing. Slider boards and the like aren't terrible, got a few from salvage a while back and I see them on ebay on the regular. New, about $1kUSD.
