Hi everyone,
I recently picked up a Mimaki UCJV300-160 and could use some help tracking down this error:
SYSTEM HALT (1) 1c3 SLDR2H
I inspected and powered on the machine before buying it, and it wasn’t showing this error. It only started appearing after I moved it.
So far, I’ve:
Removing fuses from the main board does change the error codes. That suggests it’s detecting at least some faults, but I realise it doesn’t necessarily rule out a main board issue.
Has anyone dealt with this error before? Could something have been disturbed during transport.
Any guidance on what to check next would be appreciated. Thanks!
So far, I’ve:
- Checked the cables running through the drag chain for continuity. All tested OK.
- Checked the ribbon cables between the G5HDC PCB and HDC RL PCB.
- Unplugged and reseated all cables connecting the main board and carriage board.
- Tested the printhead cables for continuity.
- Checked all fuses on both the carriage board and main board.
- Followed section 7.2.1 of the maintenance manual to check the printhead and G5HDC PCB for damage. The resistance readings and fuses all checked out.
- Im getting power in the Carriage board as i can see the LEDs light up there,
