UJF 6042 MKi blowing out X motors
btxmedia
Not uncommon for motors to be pulling constant amperage when on to maintain position or braking. .45A at 24V is ~11W, or ~21W at 48V. Not a huge draw for these motors, and to be expected.
Ok makes sense. The motor housing only gets about 8 degrees warmer than ambient temperature on idle. Also noticed the amp draw when idle can change based on what the printer last did or where it idles - carriage in the front waiting for a Rasterlink job to start is lower than parked at the origin. There's no consistent draw.
Max current on jobs today was was 4.5A for forward travel, 3.7A reverse. Doesn't sound like it's too bad there.
Servo motors draw current to remain in position unlike standard motors. Hence the small current draw. See if the current increases if you push it with your finger.. It shouldn't move and the current should rise.
Test the psu voltages in AC mode.. Make sure no caps have failed.. Shouldn't have much AC present on dc lines. If you do, could be a bad psu
I think you're getting me to check for an AC ripple? Will try that when I get some time.
am i incorrect they would draw current to stay in position AGAINST A LOAD? for instance if the movement was vertical and gravity acted on carriage weight.
1/2 amp is a fair amount of heat to "piss away" standing still.
you mention a really good point, though, is this a situation where some of the caps (or just one) has high ESR?
do you think it would help if i offered to loan him an analog ESR meter (there is a lot to be said for a simple GO - NO GO test)
Thank you but I'm afraid I wouldn't be able to use it correctly, there are about 20 caps inside the power supply housing. All previous tests I did on the supply it seemed fine for stable DC output under a fake load.
Unfortunately it's not that simple as if you touch a servo motor you'll notice a slight vibration - this is because the motor is trying to move to the commanded position, yet there's always a slight overshot (inertia of mechanical components) - so it's usually never "Exactly" at the right point so oscillates slightly (fractions of a mm) - whilst a stepper motor has discrete steps.
500ma is nothing when you consider the moving mass it's constantly trying to keep in position - even if it's not "moving".
An ESR Tester would be a good idea.. Most issues usually have a PSU fault to start with.
I really appreciate all yalls help on this!
the reason i suggested my 30 year old ESR tester is you just look for meter deflection
good capacitor meter swings to the other side
bad capacitor almost no deflection
10 second in circuit test
Vassago
Been here a while..
That sounds easy..
Vassago
Been here a while..
Caps often have a lifespan - usually 10 years or so for a good brand.. Many continue on for decades.. Some fail after months.. Checking for ac ripple is an easy test - obviously shouldn't be any on a dc line (although smps will produce some by nature of their operation, it shouldn't be much). This ac ripple can do all sorts of weird things - anything digital is the first thing to be affected. Best thing about caps is that theyre pretty easy to replace, and CHEAP.. lol
We went crazy making electrolytics much smaller in the late 1980’s.
the caps would leak electrolyte onto the board, and EVERYTHING ran hotter because of the ripple.
we got a bit smarter in the way we produce electrolytics.
I only use my ESR meter once or twice a month now, but it is still a valuable tool
