what is required to do a pressure check? the air pump does run a lot more than it should seems likeClogged bleeder filter on the dampers for me results in issues with filling with me, yeah, tied into the same system. The air solenoids, when bad tend to be clogged with ink (check clear lines leading to them for signs of ink getting into those lines). Or, when the seals go wonky, the air pump will run near constantly. But, on those notes, good to do a pressure check.
If you have your install guide that came with the printer, that covers the routing. Should be under menu> #TEST > PRESSURE if I remember correctly.
I checked the Mimaki website but all I could find was the Operation Manual and I didn't see anything about setting up the machine in there.If you have the installation/setup guide (Can download from Mimaki as well), it shows how to set the pressure on the printer. Usually done on installation, but those valves can creep out over time.
I actually found the hard copy that can with the printer, I'm going through it nowI checked the Mimaki website but all I could find was the Operation Manual and I didn't see anything about setting up the machine in there.
Where can I find the throttle valve that is mentioned in the installation guide?If you have the installation/setup guide (Can download from Mimaki as well), it shows how to set the pressure on the printer. Usually done on installation, but those valves can creep out over time.
Mine read 15. Was this your issue not enough positive pressure?Finally had time to get back to this.
This is the negative pressure
This is the positive pressure
Not sure if I'm checking them correctly?
