Unicorn Material - What is it?
JTBoh
I sell signage and signage accessories.
When I first started in signs ~10 years ago, we had a sheet of 1/4" material that was a rigid PVC. I.E. it didn't bend, and would snap if you tried. It is harder than PVC, and has a very flat surface
I haven't seen any since.
Now, have a customer with that same material and needs it V-carved.
I remember that I looked over specs for Komacel, Komatex, Sintra, etc. and just can't recall which one this is.
eahicks
That's probably Type 1 PVC. I believe it is much more rigid (due to less foam expansion in manufacturing). Somewhere between normal expanded PVC and PVC pipe.
ChrisN
I think 6mm Komacel (glossy surface) is fairly rigid. It's a lot more rigid than Palight 6mm, from what I recall.
AKwrapguy
We have a material we call Aconyl, it's a PVC. It's rigid, and will snap but only in one direction... also super cheap.
Johnny Best
There is type l and type lol pvc, if I remember right, type ll is use for bathroom walls and has a smooth surface and harder, not foam cell like sign companies use. It holds up better from chemicals and more of a solid material. Do not remember it breaking easily.
JTBoh
Thanks for responses.
6mm, It has the rigidity of PVC pipe... looks like we have some disagreement on whether it is type 1 or type 2.
Anyone have a brand name I can spec since we'll be outsourcing?
It's definitely not colorcore.
Image shows edge, as well as routed 1/8 deep letter. You can see why we're replacing lol.
eahicks
It may be Type II actually....I think it is denser than Type I
ChrisN
Sure looks like solid PVC. The glossy face foamed pvc doesn't like that inside, not even the 6mm sheets.
You might want to look KOMADUR PVC from Kommerling. It's a Type I PVC and I don't think it's foamed. (I haven't actually seen a physical sample of it though.)
FWIW, I found this on the difference between Type I & II PVC: http://www.plasticsintl.com/pvc.htm
PVC Type 1 sheet is a very commonly used thermoplastic sheet. PVC is typically well known for resistance to flame, electrical, water, chemical, and abrasion in various applications. PVC sheet comes in various grades: Type 1 (most common, general purpose), Type 2 (more impact resistant than Type 1) for complex fabrication, and foamed PVC (lighter weight) for signage applications. PVC generally is used in various application where it’s combination of properties solve a variety of challenges for machined parts.
