Urgent Help about Sp300 Sensor
damonCA21
It is an encoder sensor, but there should be a black cover over diodes so it won't work like that. Can you post a pic of the front of the board and I should be able to work out which one it is as the printer has various ones in different places
FALCON
The cover is broken
This sensor is behind the cleaning section
damonCA21
The cover is broken
Yes, it is the wiper position sensor, it tells the printer when the wipers have moved and gone back into the correct position. If this is faulty the printer wont initialise properly. I have the sensors in stock if you need one
  • I Appreciate You
Reactions: 1 users
FALCON
Thank you
Do you know exactly where it will be installed?
damonCA21
Thank you
It connects to the right hand side of the cleaning station as you look at it from the front, towards the back. You should see a hole where the sensor diodes part fits through
  • First Place
FALCON
:)THANKS A MILLION:)​
I REALLY APPRECIATE IT​
