V carving in Enroute 4
mitch2374
I am trying to figure out in Enroute 4 how to v carve following the contour, not a male or female path. There is a box that I check that follows the contour however the Gerber Sabre 408 we use will not cut it. It just floats above the material whenever I check that box. Anybody know what step I'm missing here?
Ian Stewart-Koster
Older Greyer Brushie
"Just do it".
Select the vectors wanted.
Select the create tooolpath>engrave (vee) toolpath option.
Select a conic tool & edit the options (depth, speed etc)
Click 'follow contour' in the main engrave toolpath window, instead of 3D male or 3D female path.
(I'm writing this from memory-EnR is not on this PC, but that's all there is to it.)
