Here's a question for you all.
Whenever and if ever you manually run flush fluid from a syringe into your print head, is it difficult to push it through or does it flow nicely from the syringe out through the head?
When doing it I find that I have to press pretty firmly in order to get the flush running out of the head.
Right now I'm having issues with the black nozzles not printing much out of them and the nozzle test shows consistently the same nozzles sending ink (which is less than half). I pushed some fluid through the head while still sitting in the carriage and found it harder than normal to get anything out.
Pulling ink through the damper works like a charm.
Your thoughts and response on the matter will be greatly appreciated.
jc
jc
