graphicsphere
Custom Signs & Graphics
Hi I have a VG2-540 I completely refurbished with brand new heads with brand new dampers. I checked all the choke valves, pressure pumps, waste pumps and all Ink lines throughout and everything was flushed and ink renewed with brand new ink.
The problem I have is some of the dampers seem to be emptying when sitting overnight after I checked they were full. The dampers aren’t completely empty but I notice a good amount missing in some of them. I suspect it is happening after the automatic daily cleaning.
I read somewhere that a lot of problems are with the damper fill sensors on these machines if the machine wasn’t always serviced regularly which is why I might suspect the damper fill sensors causing my problems. Does anybody have any suggestions on how to check the damper fill sensors? Also how full should the dampers be? Should all dampers be at the same level? Should all damper arms be the same amount apart outside the damper fill sensors?
If the damper loses ink and the damper arm moves in front of the damper fill sensor it should automatically turn the pressure pump on and fill the damper? Do the damper fill sensors need adjusting? At what exact point should the damper fill sensor be triggering the damper fill?
Most importantly should you ever manually push on the damper arm to manually fill the damper because watching some videos online I saw somebody do that and think that is probably wrong to do since damper fill sensors are there for a reason and why would you manually push on the damper arm to manually fill the damper when the VG series printers are supposed to fill the dampers automatically when it gets low?
