Need Help Vinyl Graphic Failing After Only 3 Years
the_silver_rider
So I just started working for a new company in Maryland. One of our clients got back to us saying that their vinyl graphics were failing. I went out to take a look and have been trying to figure out why. They were installed in late 2022 using laminated General Formulations 203 Perm Adhesive Vinyl. I have attached the initial installation files as well as the images of what parts are failing. The strange part is that only a few areas of the graphic are failing. The rest of the graphic is still quite stuck to the windows. As you can see in the images it appears that the adhesive is still adhered to the window where the vinyl has peeled away. Also there was no deformations or stretching in the vinyl, so I doubt that someone picked at the graphic. This client does have silver/reflective tint applied to the inside of their windows. So one of our theories, other than getting a bad roll of vinyl, is that maybe it has something to do with heat and the silver/reflective tint. .maybe?? Any ideas anyone??
the_silver_rider
Also, our current plan is to have any parts with failing sections removed, then to print on 3M IJ80 and reinstall.
  • Agree
Reactions: 1 user
Boudica
GF 203 is a calendered vinyl.
You will have more success and longer life with 180 - a cast vinyl.
  • Agree
Reactions: 2 users
Stacey K
I like making signs
I think using the cast will solve the problem. If you have a full panel, you can also use edge tape like many of us use for window perf material (if you think the silver edge is partially to blame). Maybe the window washing person is catching that top edge of that wave design with the squeegee? Maybe you could use edge tape on that also, not sure how that would look but just throwing it out there.
  • Agree
Reactions: 1 users
Trying to piece together what I'm looking at. Is it basically the top areas and side edges peeling ?? Nothing along the bottom ??
the_silver_rider
Yeah I should have took zoomed out pictures when I was on site. Basically, the issues are all on the bottom half of the windows, but at the top of those graphics. Parts of the curves and the tops of the peoples heads. The top bar seemed 100% fine when I was there. Does that make more sense?
signheremd
I think the silver tinted windows are reflecting sunlight back onto the adhesive side of the vinyl - angle of the sun would cause only the top edge of the bottom graphics to receive this reflected sunlight. That would also explain the two adhesive marks from the graphic shrinking in one of your photos. A good cast vinyl for the reprint should stand up to this (be sure to use a cast laminate so thermal expansion and contraction will match).
  • Agree
Reactions: 1 users
Texas_Signmaker
Very Active Signmaker
might also pay attention to prepping the glass more. Sometimes that happens when it's slick and it needs to IPA to roughen up
  • Agree
Reactions: 1 user
JBurton
Signtologist
My money is on shrinking calendared. If you zoom, you can see 3 distinct edges, where the material shrank up, but didn't let go. I guess in this respect it's like a tree, count the rings to gauge the age.
  • Agree
Reactions: 2 users
You'll get these kinda results from people either using harsh chemicals when cleaning the glass and it remains around the edges..... slowly eating away at the adhesive or possible incorrect squeegeeing when cleaning the windows. It happens all the time with vehicles, if you don't give the customer a to do list and a NOT to do list.
  • Agree
Reactions: 2 users
Calendar materials only last 3 years . It’s just at the end of its life and needs to be replaced. All above is good advice but these materials do not last forever.
  • Agree
Reactions: 4 users
MarkSnelling
Mark Snelling - Hasco Graphics
I'm not here to argue, but Gen Form 203 is a polymeric calendared that is a 5 year performing film. You can go even higher performing polymerics which will perform for 7 years.
  • Agree
Reactions: 1 users
You’re correct and this is Perfect example as to reference the product bulletin. Outdoor durability: Up to 5 years (unprinted; may vary with ink/lamination) we need to consider the laminate. Laminate, takes all the environmental impact and those typically have an outdoor life of 3 years . Also, what zone of the country? 1 ? Zone 2 . Which direction do the graphic face, North ? South? There are so many factors which all have been pointed out and more are possible so the failure is difficult diagnosis for us not seeing this in person. Reach out to your vendors and manufacturer reps for help with replacement recommendations
  • Agree
Reactions: 1 users
