Vinyl wrap (no print) on 25' bobtail
Steve C.
A customer wants me to cover his truck with white vinyl. Just the two side of a 25' box, approx. 190 sqft per side. It has a lot of rivets. This truck has vinyl lettering on it that has been painted over and is coming up in some places, but all has been painted over. It is all white with some fairly deep scratches.
I have told him he should remove the old vinyl and repaint, but I can't convence him. He insist that vinyl will not scratch like the paint and just wants a price to cover it as is. After the plain white vinyl is applied he wants vinyl signs applied to that. This is a customer I have been doing signs for for some time so it will be just like the trucks we've done in the past, just covered with vinyl first.
So how would you go about figuring a price for this. Estimated time plus materials? What vinyl would be best? Orajet 3951? What would you charge?
iSign
I just quoted an install-only wrap for a guy who I have done a lot of work for (also the realtor who found me my house 4 years ago)
I told him in his case (lotsa graphics, but not a "true" wrap) that it might be 6 to 8 hours... but he could go hourly (@ $80 an hour) or I could give a frim quote based on estimated hours... but that would be somewhat of a gamble for both of us (mostly him though, because I pad my estimates to give me the best shot at not regretting my bids) He agreed to go with straight hourly work on the clock.
Checkers
Hiya Steve,
I would charge the same, if not more than a real job. The amount of headaches you'll have just trying to make it work will offset any savings of production or design.
Checkers
seaviewsigns
i had a customer with a similar request last summer. his industrial building had decorative panels near the entrance that were falling apart. he wanted me to cover the existing panels with aluminum that had been "wrapped" in "his color" vinyl. i tried and tried to talk him into letting me just shoot them, but that wasn't going to be an option. i charged by the foot for the vinyl and doubled the price of the aluminum then added on how many hours i though it'd take. i ended up making a rig to hold a 48" roll of vinyl above low saw-horses then applied the vinyl with rapid tac. i didn't even bother using transfer tape, just a squeegy with a velcro strip. it was MUCH easier than i expected, but you will run into an issue by not applying wet b/c of the rivets. i'd suggest using a 48" roll of white but the transfer tape is going to be a pain in the butt. maybe someone on here has some hints on easier ways to mask panels that large. if you can, lightly mist the exposed vinyl as you're ready to apply so it won't stick to itself. i know it's a no-no with rivets, but i'd suggest just a fine mist. it'll make it easier to avoid wrinkles. i'll take a pic of the panels tomorrow if i think of it.
no matter how you do it, it's time consuming and you'll use TONS of material... price accordingly!!!!
cory
wildside
if you have a large format laminator...
we put the vinyl roll on the machine, no mask, and run the aluminum through just like anything else, works perfect, no wrinkles, bubbles, or wet app..this is for seperate flat panels of course
with rivets, doing by hand is the best way, mask will get you in a bind, although i have had success both ways, experience tells you best way to go
