Need Help VJ 1624 encoder 068 error
Buzzefretz2000
Good morning,
my machine was off and the head carriage was in the middle of the printer, I turned the printer on and noticed that the carriage was not in its home position so as the machine was turning on I gave the carriage a little push towards home, it was moving when the machine turned on and I got the 068 encoder error. I turned the machine off and moved the carriage to the home position and still get the error, I get it no matter where the carriage is., I've tried unplugging and all that and I still get the error. my theory is because the carriage was moving when the machine came on that the position is not in the same place and the machine doesn't know where the carriage is. it seems like if I could just reset home position id have a chance. Any thoughts anyone?
Nanci
Good morning,
The carriage shouldn’t be in the middle because when you turn the printer off it’s always in its “home”.
Maybe it got the error while running and you didn’t notice
Try cleaning the encoder strip
I was getting encoder errors while cleaning. Cleaning the strip fixed it. A bit of ink had splashed onto it
Umca
If you turned the printer on and it detects the carriage not in the Home position, the carriage motor activating until the carriage will reach Home sensor. CR encoder does not using withing this moving. Just slow motion by the CR motor. You can use this for detect if it the motor problem or encoder problem.
Buzzefretz2000
Thank you for your response, Nanci, it was in the middle because i got a error while printing, I had to turn off the machine
Buzzefretz2000
UMCA, thank you, I want to try what you say, could you explain a little more please?
