Nuage,
I just did a similar thing: I cut numerals 1 through 90, 26 times (around 4500 numerals total) as well as A though Z 2 times. 1-90 were 1.25" and A-Z were 2.625". I used high perfomance black for 1-90 and high performance white for A-Z. Vinyl cost was about $90. To cut, weed, and tape them all, it took me 4 hours. I charged my client $550. Sounds like a lot, but if you break it down to 12 cents per numeral it really does not sound that bad! Aside from that, I checked the local
sign wholesale / retail giant and they advertise 26 cents per 1" letter! Also, I did not cut apart each numeral or letter, but gave them to him in sheets for him to do so.
You can always give a little bit of a break for volume with vinyl as you do get faster when weeding the same thing over and over. However, the intensive labor is still there, so don't give it away. I believe where you make your money is weeding while your plotter is cutting!
Weed 'em and reap...
Good luck!
James
