Volume pricing?
Nuagedesigns
Never really done high volume before on standard cut vinyl Customer to install. I was aked to do around 500 5in & 4in. tall double digit standard block Black Vinyl letters for a customert today. (sample: A1, A2, etc.) Not sure what a fair price is for this much volume. Customer will be bringinging in alot more work and don't want to over price or under cut myself on this job. Where would you guys stand on a job like this. Thank you for any input.
The Dotted Line
The Dotted Line
Nuage,
I just did a similar thing: I cut numerals 1 through 90, 26 times (around 4500 numerals total) as well as A though Z 2 times. 1-90 were 1.25" and A-Z were 2.625". I used high perfomance black for 1-90 and high performance white for A-Z. Vinyl cost was about $90. To cut, weed, and tape them all, it took me 4 hours. I charged my client $550. Sounds like a lot, but if you break it down to 12 cents per numeral it really does not sound that bad! Aside from that, I checked the local sign wholesale / retail giant and they advertise 26 cents per 1" letter! Also, I did not cut apart each numeral or letter, but gave them to him in sheets for him to do so.
You can always give a little bit of a break for volume with vinyl as you do get faster when weeding the same thing over and over. However, the intensive labor is still there, so don't give it away. I believe where you make your money is weeding while your plotter is cutting!
Weed 'em and reap...
Good luck!
James
Pro Image
4x5 would run in 500 qut. .50 to .75 each around here............You mignt get more in your neck of the woods............
WB
I'd still base it on sq. ft. if it warrants a volume discount take 20-30% off..
Express Sign
we just completed a slightly smaller job like what your presenting here and charged $2 a number for 250 pieces, but we also had to cut the letters after masking them that took some time.
