VS540i blobby issue with nozzle check
huddsphil
Hi all,
Thank you for accepting me in. I'm new to this forum.
I have a VS540i for the last 3 years, was working perfectly until last weekend got a scan motor error 44 I think. This happened some point Saturday after closing 12:30, came in to work Monday and error showing.
Cap top, wiper, felt all replaced 3 weeks ago.
Print head was sitting uncapped 5" into the media area all weekend.
Monday morning I replaced the scan motor clearing the error code.
After several medium cleans the nozzle check was blank.
I then head soaked for 3 hours with a small number of nozzles then firing.
Another head soak that evening until the following morning, most of the nozzles were now firing Tuesday morning.
After several medium cleans and another 3 hour head soak the head was beginning to look it's old self but on closer inspection the lines were looking blobby and not smooth as in the attached image.
If I run a solid 700mm x 500mm rainbow pattern test piece the lines improved greatly almost 95% perfect, the next morning they are blobby again.
What else can I do/change to get it running perfect, have I missed anything.
Cheer in advance.
damonCA21
That is a very weird test print ! Get a torch and magnifying glass and see if there is anything on the printhead face. Also check the captops, wipers etc. for any stray hairs.
It is likely the drying out and then soaking and cleaning has left nozzle damage. Too much cleaning can do this but its unusual for it to effect all the nozzles equally like on yours
To me it looks like the vinyl is sweating plasticizer or the ink is separating. Do you use a bulk system?
huddsphil
Hi, I've done the zoom-in check for hairs/fibers and all is clean. Had the cap top, felt and wiper changed about 3 weeks ago with oem genuine parts.
The strange thing is after a good test print the nozzle test print is fine then the next morning its back to been blobby
huddsphil
This happens on any media, photo, banner, vinyl, pop-up its only better once I do a decent size with my test print. I was beginning to think possibly the dampers but not 100% sure as its all nozzles
damonCA21
Tomorrow morning after leaving overnight and before printing anything, look at the face of the head and see if it has ink on it. Perhaps ink is seeping through which would account for the bad test print, then when it starts printing this clears as the head doesnt deliver much ink during that.
It could be a captop problem, or possibly your pump. Sometimes a failing pump can cause a vacuum and can draw ink through the heads into the captop when it is left overnight. If this doesn't soak away then it could leave ink sitting on the face of the head.
What you can also try is when you first turn the machine on, do a light head clean then the test print and see if this helps
huddsphil
The cap top, felt and wiper changed about 3 weeks ago
Print head face is nice, clean and dry.
I replaced the pump at the same time as the scan motor
huddsphil
It had crossed my mind that it may be that, but after doing my rainbow test print, it performs perfectly all day, then it sits all night and the next morning has blobby issue, makes me think its an ink flow to the head or possibly a damper issue.
huddsphil
yeah it's next job on my list, not a clean job though how I see it, think I need to clamp all ink lines unless there's an easier way without ink spill
huddsphil
UPDATE....
Having replaced all the dampers there is a slight improvement but I still have the bobbly effect on the nozzle test print.
If I do my rainbow test pattern
the nozzle check is much better but not perfect
IMG_20230715_092119.jpg .
pictures attached,
Is there anything else I could try before I bite the bullet with a new printhead?
damonCA21
I think it is probably new head time. The multiple soaks and cleanings could have damaged the nozzles, and you have ruled out pretty much everything else that could be a cause
huddsphil
That's sad news, it runs almost perfect after the cleans until the following morning, I will have to live with this a little longer doing the head cleans in a morning, £1k - £2k for the head is a big up front hit for the sake of a couple of cleans.
Thanks Damon and the other guys for all your input/help.
damonCA21
If it prints ok after the clean, I would keep doing that for as long as possible to put off having to get the new head. You never know it may fix itself over time.
