Greetings!
We are producing a digitally printed wall graphic on Oracal 3628 with 210 matte laminate. It will consist of four vertical panels. My question is, would you put an overlap between the panels, and if so, by how much? The graphic is going on to semi-gloss painted drywall.
Graham
Graham
Reason they do, is the adhesive is not cured with the same process we use. Also the Photo Tex adhesive is 100% cured and therefore you do not need to remove after 6 months and worry about residue or damage to a wall. Read everyone's technical bulletin and compare. I am happy to send anyone a free sample to compare and if price is an issue, simply ask me.
