Wavy window perf when printing
Josh Kuper
Printing solid black on window perf, we have an HP latex 115 and we have our normal Perf Profile set up but this one isn't working for us. I can't find any topics to help, we reduced the heat and bumped up the vacuum but it gets wavy in the middle then the heads touch and scrapes the print, any ideas.
balstestrat
Problem Solver
Add some tension to it so it's being pulled down. More vacuum and even less heat.
Change to a different brand.
Steenland
Old Member
I had a heck of a time trying to get perf through our Latex 365 without scuffs in the curing area. More vacuum and less heat definitely helped, but what finally worked was adding the counterweights to the back of the take-up reel. I've found that if the media skew is not absolutely perfect (and it never is), the media can't roll perfectly flat onto the take-up reel, and the resulting wave backs up into the curing area. Using the counter weights to relieve some of the tension helped a lot.
Z SIGNS
If you can't figure it out keep the roll anyhow. Save it. Design and sell a grunge design where it doesn't matter.
Ugh, ruined many a window perf prints. Finally have had consistent runs with Briteline 65/35 and 50/50 using generic vinyl profile or HP One View Perforated Graphics. HP 570 is our workhorse.
Michael-Nola
I print things. It is very exciting.
The proper solution is to quit HP Latex altogether. I know no one wants to hear it though ... Latex requires a decent amount of heat to dry, perf hates heat while printing, there's no perfect solution here.
Precision
We had the same problem with our HP Latex 360, using Briteline. Switched to General Formulations Windowmark 70/30. Our perf jobs have been great ever since we changed.
MarkSnelling
Are you still using the Sihl 80-20? I was wanting to switch to it since I have read that non coated liner is best. Was wondering what your experience with it was.
Try Continental Panorama One. Awesome film, great liner, and amazing price. I sell it for $391 for a 54x164.
I’ve had success with printing fast . Single pass, lowest resolution. If materials sit on the heaters too long it will begins to wrinkle. Use if a perf with a poly liner helps this too .
Geneva Olson
Expert Storyteller
increase the vacuum on your printer and add weights for tension when it's coming out. I place 5 sets of magnets on the end of the lead to start out and then i babysit and roll tight.
Well, I used to babysit until I got my take up reel (HP315). I don't think the 115 comes with an option of a take up reel.
Geneva Olson
Expert Storyteller
I use window perf all the time in my hp 315. I've had fits with it in the past, but there IS a solution for it.
