Welcome from Glasgow Scotland
T-DEX
Just want to say thank you for accepting me into this forum.
I have a small issue i would like to disuss if ok with everyone.
James Gallant
Graphic Designer
Welcome. Feel free to post about your issue. I'm sure someone hear would be happy to try and assist you resolve it.
  • Agree
Reactions: 1 user
T-DEX
Thank you
I have created a post with the issues i am having with my SP-300v
Regards
Tommy
ringocat22
Hi Tommy - I used to have that printer, I may be able to help. What's the issue? I'm on the road most of today, but I'll reply as soon as I can.
T-DEX
Got some banding through all colours, not sure what it is exactly, hoping not the heads. It wasn't printing very well, but got it printing though i have some banding or ghost colours now. Trying to recalibrate the full machine from the very start and aline print/cut and all that. Any help apreciated.
James Gallant
Graphic Designer
If you could post a photo of what you're getting and maybe also a nozzle test, it may help to give you better advice.
T-DEX
This is a test print along with what i am experiencing right now. The banding is within the picture at bottom.
James Gallant
Graphic Designer
Thanks for posting that. That head certainly has damage to it and a bit of deflecting nozzles, which is the cause of the overspray you're seeing. Unfortunately the only real solution for this is to replace the heads.
T-DEX
Are we talking both heads or just the black one. This is my first serious issue with this printer as it was printing fine, then the next job i done it ended like this. No head strikes and routine maintenance.
James Gallant
Graphic Designer
Both heads, the overspray is from the magenta nozzle deflections and I could be wrong, but the black head does look like it had a head strike. You could try doing a 48 hour head soak, by shutting off the power, then capping the lines after the cap tops and filling the cap tops with cleaning solution and putting the head back into the capped position and let it sit, then reapply liquid after 24 hour and after 48 hours try a cleaning and a test print, if no improvement, then the heads will need replacing.
T-DEX
Thank you for this, i will give that a go after the weekend as working. I will keep you posted as to the results. Not going to hold my breath though.
John_Smith
Enjoying retirement in Central Florida
Welcome to the forum.
I spent some time visiting Holy Loch back in my US Navy days in the '60s - '70s on various ships.
(almost got married there in Glasgow twice). :eek:
