Went through shopvox, corebridge, cyrious, signtracker and onprintshop. they all organise the floor the same way
Horton Signs
Our system uses stages (Quote/Print/Laminate/Cut/Weed/Apply/Install etc) but we also have materials (with ability to add detail: e.g. either a colour, if the material is a coloured vinyl, or a laminate, if printed) and we're able to sort based on Status AND material, so we can sort based on Print and "IJ180mC", or Cut and "Avery 901 Black". So it kind of helps us get around this to ensure we're running our similar materials together. These material details are predefined so we can sort knowing they're correct. Could work well for laminating too, especially as many films use the same over-laminate, however, this then normally becomes a physical check, where we have physical zones to stand all our rolls (with changeable tags), e.g. put all our rolls of DPF4500G Clear and DPF4600LX into a zone called 3420G for the laminate type and finish.
Foremander
That's the bit most of them can't do. Sorting on status and material together is what I was getting at, and it's why the ones that only give you a stage fall down.
The laminate zones are the part I keep thinking about. You're not grouping by what the material is, you're grouping by what it takes. DPF4500G and DPF4600LX are different films but they end up in the same zone because the overlam is the same. That's a step past batching by material and I hadn't framed it that way before.
Is that mapping in the software, or is it the physical tags and everyone just knows? Reason I ask is if the film carries its own laminate, the queue could build itself instead of someone remembering which rolls belong together. Same for the coloured vinyl detail you mentioned.
What are you running?
Horton Signs
The software allows you to assign different laminates depending type of film chosen and these are set under "materials management" as an "embellishment"/"finishes". So for DPF4600LX you can chose 3420 Matt/3420 Gloss/3420 Satin and 3270 Gloss. The finish gets assigned at the design stage based on location/lighting conditions, client expectations etc. We also have physical carboard "mushrooms" that go in the ends of the rolls that have the film name, supplier etc and on the back side of that it has the list of compatible laminates; but it gets pulled through from the job info in the software. When we prepress we call our files "DPF4600 3420 MATT ClientName JobRef#.pdf" so that within the RIP we can see at a glance all the files that need to be nested together. The filename also gets printed in the corner of every job to act as a double-check for the print operators/laminators, so that even if it's not the same person everyone knows what needs doing and using what film, without then needed to check every job back against the software.
The software is an in-house built system I've developed over the last 12 years, initially all it did was act as a CRM to track customer details, appointments and interactions, then I added quoting and invoicing, scheduling & timekeeping, inventory management, artwork approval, reporting and export to Xero (through their API), Freighting, 3CX/ClickSend/Twilio/MSGraph integration for more detailed client interactions. It's a labour of love...or something like that. Never got around to making it multi-tenanted and with the rise of AI, people are just developing their own software now, so makes even less sense.
serena lin
I understand your point.It’s very inconvenient that the same production step across different orders can’t be managed uniformly. We recently switched to a new system from a long-established Chinese company. What sets theirs apart is that it allows for customizing production steps and filtering tasks under the same step to export them to Excel. So far, it’s been fairly easy to use.
Most importantly, the price is very reasonable for small and medium-sized businesses.
Foremander
Horton Signs, sorry for the slow reply. the laminate getting set per film in materials management is exactly the bit i was asking about, and 12 years on your own system is no joke, thats more than most of the paid ones manage.
Pauly, not really kanban for most of us i think, more stages with workarounds bolted on, which is kind of what this whole thread turned into
quick update since a few of you helped shape it. its been running at my brothers shop every day and a handful of other shops are on it now too. one runs their bigcommerce store straight into it so web orders just show up. this week we added yard sign kits that pull from stock, posts stakes and frames count down when the order goes in, because thats what my brother actually needed.
its called printerflo if anyones curious, theres a free trial. but honestly the material side is still the part im most interested in, how other shops group their runs. hortons laminate zones gave me an idea for whats next
