What adhesive would work sticking a plastic engraved strip onto a concrete pole outdoors in December with below freezing temps?
gabagoo
I told my customer I would ask if there was anything to do this, so I ask the pro's here. I just have to supply the pole numbers but warned them that I am not sure if there is anything that will work in below freezing temps. Typically following some old spec ( which is just plain wrong) for the city and the poles are already installed.
Any glue your lil' heart desires and back it up with....... TAPCONS.
  • Agree
Reactions: 1 user
Tel them to wait til spring and try again. Unless you can blow some hot air on it for 24 or 48 hours, I doubt much of anything will have any initial stick-to-it-ness.
gabagoo
I'm not installing , just supplying... I think the original spec was for wooden poles and you could screw them in. Not to many wooden poles anymore in subdivisions. I suggested waiting till spring but they have to be done... The Tapcons might be the way to go
Moze
I would recommend Spax #8 exterior wafer head screws. They would look a whole lot cleaner than Tapcons and require a smaller hole.
