What do these smears mean? HP latex
danno
Negative Ghost Rider, the pattern is full.
It looks like something is on the bottom of the carriage. Is the print quality good on a production piece?
DChorbowski
Pixel Pusher
Do you happen to have a shop dog or cat? I agree with danno, looks like hair on bottom of print carriage thats getting dragged through the uncured ink while its printing.
Reactions: 1 users
Precision
SoCal Signmaker
Open up your print head carriage as if you were going to change a print head. Check the printheads closest to you (front row) first. I bet they are good but have ink built up. These are latex so either using the stuff provided with your maintenence cleaning lit or just a micro Fibre towel and water. Once you finish the front do the back row. Then see if that helps.
Reactions: 1 users
I have this happen on my crappy test material I use to run the printhead maintenance and tests with. It just doesn't seem to want to absorb/cure the ink on that material but looks fine on the regular vinyl I run with the same tests. HP 360
ozpall
i get something like it if the media profile i select doesn't like the type of vinyl i use. usually with gloss poster paper if i select HP Photo paper it does something similar.
