What files for logo design?
ADM
Hello All,
I cannot begin to mention the amount of help this forum has been...
Anyway, when doing logo work for a customer, what files and formats do you give the customer for future use?
PDF?
JPEG?
EPS?
AI?
All of the above?
Thanks again,
RS
iSign
all of the above is helpful to them, & much easier to do it one time, burn it for them & not get the call later... "I can't open an .eps... can I get a .jpg to email my mother/brother/cousin... to show off my new logo"
Fred Weiss
I usually supply
  • EPS (version 3)
  • WMF (best for Microsoft applications)
  • JPG (at near full page size and at 72 ppi)
  • TIF (at near full page size and at 300 ppi)
  • PDF
Bobby H
Arial Sucks.
You should vary the formats supplied to a customer on a case by case basis.
If I do a logo design for someone and they do a "full buyout" then I'll supply the following formats:
Acrobat PDF (1.4)
EPS legacy version 3
Illustrator legacy version 3
CorelDRAW 8
Macromedia Flash .FLA & .SWF
TIFF
GIF
If its a sign customer who tends to do a bit of shopping around, I'll only supply rasterized files. If he needs the art for a certain kind of print job, I'll supply the artwork in the appropriate size and resolution for the job.
Basically you should only let go of vector files only when you've been fully paid for them. They're not something that should fall into the hands of competitors.
logomotive
The MORE you supply to the "average" client the more confusion this will add, the file they will most likely send out for reproduction will be the low res. bitmap. I make a stong statement to use the superior Vector EPS or AI files even though in most cases they cannot see what they are sending. I spend as much time educating the client as prepping the files. What you do send them is exactly what you state in your written contract.
Derf
I agree with Mike about the "more" confusing the client.
For me it depends on the client!
If it is a small business or home business with little knowledge of graphics I will give them a JPG, and a layered PDF made from Photoshop or Illustrator unless other wise requested.
However, For other clients, lets say for Flexographic Packaging Design, I will give them what their plate vendor wants and manage the clients files because they usually drop 2-5k on the art so I don't mind.
