What is the easiest way to cut round corners on Aluminum Composite Panel/diBond
balstestrat
Problem Solver
Probably one of the simplest if you only need it sometimes. Handheld, makes nice finish.
Reactions: 1 users
Boudica
This is similar what we use, it works great on ACM. Ours is a little more industrial looking, but it's basically the same
Reactions: 1 users
TEN
Having a scrap piece of material supporting the corner helps to minimize the bending as the cutter cuts the rounded corner. Put the support peice under the peice to be rounded. A sharper corner blade helps as well.
