What kind of lumber?
unclebun
Doing a job making some v-shaped for lease/for sale signs for a developer to install on some outlots around a shopping center. 5x10's mounted on 3 4x4's in the ground. Normally I'd use treated lumber 4x4's and stringers. But they want the 4x4's exposed all the way up at either end of the signs, and painted white. (They have to match their identical signs they use in the city). So since the posts have to be painted white, what type of lumber would you use for the posts? I could use cedar but they are 4x the price. Or do I use softwood and figure that 3-4 years for painted softwood is long enough for this type of sign before it rots out? I don't have stock of treated 4x4's aging outside for a year so I can paint them.
weyandsign
I would definitely go with treated. You do not want 5x10 V shape sign posts rotting and breaking. Tell them you recommend waiting 90 days before they paint it. Or they can choose to paint it immediately but higher chance of paint failure, warping, etc. Even if they want it painted immediately at least give the wood a week or 2 before you paint it.
Signstein
I paint treated posts all day every day. Mostly for parking and street signs that need to be replaced after being struck by vehicles. Haven't (knocks wood) had a failure yet. And I'm putting them up in 1-2 days.
Just use a good primer and paint and you'll be fine.
Johnny Best
Buy the latex paint at Home Depot that has the primer built into it. You may need two coats if the treated 4x4s are wet.
unclebun
Okay, so all the information about not painting treated lumber until it dries out is bogus and I won't have the customer coming back in a few months because all the white paint is peeling off?
For treated 4x4's or any other size, just use Solid Color Stain and roll or brush it on, unless they are dripping wet. Latex works, if you're in a warmer climate. Been doing that for over 45 years after I first found out about it.
Secret is, the stain soaks in where paint will basically sit on top and dry. You'll need a second coat, but that's not bad.
ChaseO
If the posts feel damp, the paint won't stay, trust me. Also, I'm not sure I would trust 4x4s with 5x10s. I have had wind break 4x4s with 4x8s before. It doesn't happen often, but with the storms and wind we have been getting lately, I'd be looking at 4x6 or even 6x6 personally.
visual800
and stop buting lumber at HS and lowes and gt it from lumber yrad it should be dry from these places
unclebun
netsol
exactly
if they are WET leave them in direct sun for 1-2 days
OR
in the warehouse under a hanging heater
Johnny Best
They do not do pretreated lumber like they use to the new chemicals soak in a lot better and take latex paint better, the previous “dip” had green coating that bleed into paint and did not take the paint well. The old dip was not good for the environment.
chester215
Just call me Chester.
Old treating chemical- I think was arsenic while the newer one is copper based.
Having painted thousands of pressure treated 4x4's I would recommend using posts that have dried for a while.
Some wet posts do flake after a while and some do not, it usually depends on how wet they are.
Generally the ones on the outside of the bundle are drier while the ones in the center tend to be wetter.
You can get a basic idea of how wet they are by the weight, wet posts can be 2-3x heavier than dry ones.
As mentioned previously- use a post sleeve for the best finish.
unclebun
Cheaper to buy a cedar 4x4 and stain it than treated lumber and a post sleeve. Post sleeves require a cap too which changes the look of the sign.
