What would you charge???
William
I am just curious about what you would charge to remove and replace vinyl on these vehicles. The two van trucks both sides front and back. The big truck just the sides which is 20ft long. Thank you for taking the time to help me. I dont have to replace the post.LOL
Imakesigns
There are a lot of variables to just come to a price. I usually undercharge for every removal I quote, so be careful. Charge for adhesive remover (probably one full gallon), towels, lil chizlers, propane, ladder use, breakfast, lunch, additional profit on those products, and whatever else you usually use and then figure your time. I try to charge for about 20% more time than I think I will use, but like I said before...
Fred Weiss
Or you could shop in your local market for a pressure cleaner who has a steam unit. Get a quote from him to blow them off and mark it up plus add on a couple of hours to clean up any residue.
Mike Paul
Super Active Member
Definitely charge by the hour for removal. Especially for a larger job like that.
Time is too hard to estimate correctly. Shop rate plus material.
Colin
I can see why they want them removed.....damn that's ugly. The dreaded green shadow on a white background - aaaaaaaaaagh!
Anyhoo, yes, do this job based on an hourly rate only. Give 'em a guesstimate on how long you think it will take, but let them know that if it goes quicker than expected, they only pay for that time, but if it takes longer, they also pay for that time. It's only fair to you. Get them to sign an agreement!
Do them in the sun if you can - much easier. (wear sunscreen).
Marlene
Try removing a couple of letters before you quote the removal. I learned my lesson a few years ago and test every removal before I'll bid on it. I had to remove lettering from a trailer. Just white copy on a black trailer. It was like it was welded on! I tried heat, vinyl remover and every other trick in the book and lost tons of money on that bid. I know some vinyls come off harder than others but I had never seen anything so bad. If you bid by the hour, still test as the guy will be really upset when you tell him after the fact that it took 12 hours.
Colin
Good advice by Marlene. Also, make sure (in writing) that you will not be held responsible for any lifting of the paint. Some non-factory paint jobs are done very poorly and the paint can lift off with the vinyl in some cases.
Arlo Kalon 2.0
Marlene Young said:
I learned my lesson a few years ago and test every removal before I'll bid on it. I had to remove lettering from a trailer. I lost tons of money on that bid.
To also quote OP "not to be a wiseass or anything" (believe me I'm not!), but Marlene, why did you feel OBLIGATED to go through with a losing proposition? I just always consider how the person I'm doing business with would handle any problem if the situation were reversed so to speak. Like them, I'd have no hesitation whatsoever to extricate myself once it was evident a situation existed I did not foresee that was going to cause me to lose money. I don't want customers who would still expect me to live with a price under those circumstances. I'd tell 'em where to get off in a heartbeat. Just MHO! No disrespect intended.
William
Thanks for all the replies, made me realize some of the things I left out of my original quote. Good thing I posted the pics before I commited to something. I have learned allot from everyone here and hopefully one day can pass some of it on to others as well. One other Question. Just curious as to how others price their vinyl?? Running ft? Sq. ft?? Just wondering if I am in line with others on this one. Thanks!
Colin
A DAVE 800:
One thought I had when I read your post was about the idea of "losing money" on such a job. This concept which most tradesmen refer to quite often, has some serious holes in it. Example: If I firmly quoted $360.00 on a job like this, figuring it would take me 6 hours (@ $60.00/hr), and it took me 8, 10, or 12 hours or whatever, many start to think that they're "losing" money.
This is not really the case though. We are not "losing" money, we're just not making as much as we'd like. If you spent money on adhesive remover, tools, etc etc for the job in question, and then you got paid nothing, then you'd be losing money.
Also, if you turned away other work for this job you could say that you've lost money, or if you were paying a staff member a hefty wage, but even if this job took 14 hours and it's just you, you would still be making $360.00, not losing any money. Don't get me wrong, I'm not suggesting one adopt a lax attitude towards hourly rates, quoting etc, I know I really feel it when I'm spending more time on a job than I initially thought. It just helps me maintain more of a relaxed mental attitude (peace of mind) when this does happen, and after so many years in the business, I try to see potential problems and cover my butt before getting into a job.
Just something to ponder.......
theroq
I would charge $400.00 each vehicle for cleaning up and removing and $450.00 to $800.00 to relay new vinly if similiar to this..... what's on there now.... But that without any specs...
just my two cents
GT
I'm with Mike Paul. I charge strictly for the time. I've had some cases where removal went very quickly and I've had others that would test a saint's patience.
OldPaint
"I would charge $400.00 each vehicle for cleaning up and removing and $450.00 to $800.00 to relay new vinly if similiar to this..... what's on there now.... But that without any specs"
do this and lose YOUR ASS!!!
i charge as much TO REMOVE VINYL AS I DO TO PUT IT ON!!!
they dont like it...let them get the stuff removed! my time and talent are DESIGN, LAYOUT, INSTALLATION.....body work, removing vinyl, washing the vehicle all fall under EXTRA MONEY!
lets do a little sq.ft. to dollar example.
20 ft trailer and its 6 ft tall. so your only gona do lettering(not removal)in a 4ft tall x 20 ft space on the trailer both sides would be normal and the back door is usually 6 ft x 6 ft. ok?
now yor doin intermediate vinyl at $6 sq. ft or HP @ $10 A sq.ft.
lets work with the 10..i dont have to hurt my brain this way.
4x20=80 sq.ft. x 2 = 160 sq ft. + 36 sq.ft. for back door.
and the answer is...$1600 +$360= $1960.00. now let do it in intermediate 160 sq ft. +36 sq ft =196 sq ft X $6 sq ft=$1176.00
you can go higher on the intermediate....now the removal price would be the same as the INTERMEDIATE....its gona take you as long to take it off as it does to put it on dontcha think?
time is money.......ask a lawery.....and it it will cost you $200 an hour....what are ya worth.....fast food places are payin $8 an hour here..........now you do the math...
Marlene
This happened to us a while ago and is part of the reason we came up with a contract that with a bunch of reason why the quote may change. At the time, the company just felt like it had to honor it's bid. It's a live and learn type of thing. I brought it up as there are people here new to the business. It's my hope to help some one else prevent this from happening to them.
Arlo Kalon 2.0
I thoroughly like that contract idea covering the aspects (unforeseen) that could REQUIRE a bid to change! And I sure do understand the feeling of needing to honor a bid a company w/your name on it made. You hit the nail on the head with the "live and learn" thing. Some of us should be awarded a PhD for those years of lessons, huh? I too hope advice in here will largely be taken to prevent some of our mistakes from being uselessly repeated by others. Because like I said - I HAD to learn to know when to fold 'em only because of people I was working for who would knowingly LET ME (or try to help along) lose my behind. They're out there... and when ya get down to it, at this point in the game it's gonna be ME who wins the round now!
Marlene
This site is great as we are in different places in "sign business life" and the people here are willing to help each other and help keep each other from having to learn things the hard way. I've been doing this for almost 20 years and still find things here that have stopped me from doing something I'd regret later or helped me figure out how to do something I wasn't sure of.
Fred Weiss
Check you mail for our invoice. :Coffee: :signs101:
