Where do I go from here?
HardbargerSigns
Any advice here? I'm not sure about this one...
ChiknNutz
I think I would have the shadow of McCartney go on the panel in transparent so the other colors show thru it. I'm not fond of the tilt on the McCartney...just doesn't seem to complement the design. Maybe tuck the tail of the "y" behind TRAILERS, or even on top...try them both!
HardbargerSigns
I think I would have the shadow go on the panel. I'm not fond of the tilt on the McCartney...just doesn't seem to complement the design. Maybe tuck the tail of the "y" behind trailers, or even on top...try them both!
Cheers, I'll give that a go.
I'm also considering a whole new direction... :help:
Rick
My first reaction was...why this direction?
What do they do, what style are they more inclined too use? how is the logo going to be used? who is thier target client?
iSign
maybe older looking colors, & a secondary panel.. offset above center, behind a smaller McCartney... with more flourishes in it, possibly vertical pin stripes... & a small portion extending below the trailer panel, ending in a shield style taper... with some hailing port type tag... or more flourishes
HardbargerSigns
Good advise, I'm not too sure of the clients direction, or much else about them.
It's in West Virginia, so I figured an old fashioned feel. I don't want to go TOO detailed, but enough of a design to show stability, like the've been in business for many years and will still be around.
Here is the info I have; purina mills feed dealer, Horse & Stock trailers, Utility & Cargo trailers
Equipment trailers, large inventory, aluminum & steel, custom orders
hitches & brake controllers installed, etc,etc,etc
bob
You have three elements, "McCartney", "Trailers", and the panel, all locked into a fistfight with each other. Each one is screaming "Look at me, screw those other two."
HardbargerSigns
I'm in agreement here, I think I'll try to back off on the panel a bit, make trailers larger since THAT is what the "call to action" is, and work on the McCartney a bit more.
I'll keep you all posted! Thanks for the feedback!
RedlineMan
Hey;
I don't mind it, excpet for the tilted name. I did this real quick. I might also outline the trailer in black to make it pop out a bit.
