Which Vinyl Cutter to Buy? Summa S3T160 / Graphtec / HP 64" Cutting Solution
BecW
Hi, we are looking at new vinyl cutters at work. Considering the ones in the title. Right now it's between the HP and the summa. The summa is about $10,000 more. Obviously it has true tangential technology VS only drag knife and the HP has tangential emulation only. Upon looking at videos the Summa does seem to be of much higher build quality. But I'm looking for people's opinions on their experience with these machines.
I know a summa will fit seamlessly into our current workflow as we use a very old summa d160r. It's on its way out and having major issues hence the upgrade. FYI We use our vinyl cutter every day. It needs to stand the test of time.
I work at Signarama. So lots of large format printing and cutting for a wide variety of jobs from signboards to stickers to decals to vehicle wraps. You name it everything. Including 3D signs where we need to draw on the pounce paper as a template for installation.
Tangential would be a nice upgrade. But I don't think our current d160R had tangetnial technology, and we've gotten by with running just drag technology for 12 years.
I should also mention the printer we use is a HP Latex 365 with ONYX RIP. So I believe HP vinyl cutter would fit here. However may have a learning curve and change our process, so less seamless for a busy already operating business.
What I'm really looking is;
  • Reliability and trust in the machine (parts not breaking often, cutting accuracy)
  • Ease of use
  • Future proofing. This is a long-term investment.
  • Efficiency in the workflow.
  • OPOS reading accurately over long runs. Vehicle wraps can have runs anywhere from 3 to 6 metres long at a time. On the cheaper HP I have a feeling there may be issues with long runs like this and we do a lot of them so I'd like to have that reliability. Has anyone used the HP and can tell me if they've had these problems? I did read it somewhere very briefly and it was giving somebody trouble. What sensor does it use? Is it worse or better than OPOS cam?
Please share your experiences with these machines and comparisons if you have any information. It will help us make an informed choice.
Thank you!
balstestrat
Problem Solver
That HP cutter is Summa S One. There's almost no difference at all, same factory, same model just tiny firmware differences.
Unless you get the HP branded one a lot cheaper you might as well get Summa. It's basically the same as your D160 with new design.
But if you want an upgrade, get the S3 tangential one (and I really recommend with the camera, now that's an upgrade!). If you just need a new one, get S One.
Now is it worth 10k (you can 2nd S one for that price) only you can decide. But it is more of a tank inside, not just the head is different.
cornholio
I can second what balstestrad said.
The camera version of the S3 is cool and extremely fast in marks recognition.
But I only see an advantage if you do a lot of sheet cutting. (Like screen printed sheets or prints out of a digital printer like a HP Indigo).
The S One or HP Plus are nice cutters as well.
Jessy_1
  • Ease of use
Thank you!
We use the Graphtec 9000 and I LOVE IT.
Pros:
- Will work with ONYX RIP and their opos system.
- Has a setting called Line Segmentation. This means when it goes to cut a printed file it will only scan the first 4 marks and then plot everything within that square, then once its done that section it will advance to the next 4 and so on. This is really good when you print a long cut file because it minimizes skewing. It's smart enough that it will fix itself when it does start to skew. This is by far my favorite feature. We do a lot of Vehicle wraps and stickers and I very rarely have a problem with skewing because of this feature.
- Has the plug in for Illustrator to add opos marks.
- Has 2 positions the blade can be in. Position 1 is on the cutting strip for normal kiss cut Plotting. Position 2 put the blades in a gap next to the cutting strip. Position 2 is used for perf cut. This is nice because you can perf cut without ruining your cutting strip.
- can do layered cutting. It will kiss cut the stickers out and then will go back to position 1, make you switch the positions and the proceed to perf cut the stickers.
- Not sure if this is a product you use. But it cuts Tint super well. Tint is notorious for being hard to cut (from my experience) and I haven't had a single problem cutting it with this machine.
Cons:
-you have to set the blade depth with every run, which can be very annoying
- I've noticed I go through blades fast. I'm not sure if it's a user issue or if I should look into getting a different degree blade.
- if you want to switch from a 60° to a 45° blade you have to get a whole new housing unit. It comes with the 60° blade. (I think this is why I'm going through blades because most of the stuff I cut isn't supposed to be cut with a 60° blade.)
I used to operate an HP 54" Basic cutter and a Summa S Class. And out of all 3 plotters the Graphtec blows the other 2 plotters out of the water. I highly recommend it.
