Baz
Hmmm .. That guy must have used double the amount of laminate that was needed to do the job he did. He must be a supplyer of lam film :ROFLMAO:
I'd go nuts if i had to go through all those steps each time i need to laminate something.
I have permanently removed the security guard and finger guard. I never remove the table top in front of the rollers. Whenever i need to laminate something i just pull enough lam through and let it sit on the roller and a little bit on the table top. Then push a 6" coro leaderboard and stop it with about 1-2 inches of coro exposed. I put my printed roll on the tabletop. Let about 1 inch of the print onto the coro and make sure the roll is straight (by looking how each end is alligned with the edge of the tabletop) Then attach the print onto the coro with three pieces of masking tape.
Now i can push the run button and with one hand on the pressure lever you turn it to the lam position when you feel the coro has gone through (like in the video). I regularly lam things about 16 feet long and only go off about 1/8 to 1/4". Its not that hard.
I do like his tip about putting a scrap piece of paper near the end of the print though.
