In situations like this, I always recommend running a VM (that way it is only temporary if it doesn't work) on a
computer that has the resources to support running 2 full OSs.
See about getting an ISO of Win 10. I do believe that MS has gone back to allowing you to skip the activation on original install (with Win 8, you actually had to create a file that allowed this) in order to try it out. Load it in the VM and then load your Flexi software within the VM and see if it works.
I don't know if 2002 is too old for modern OSs, I do know that CS2 (which is 2003 if I remember correctly) runs fine on Win 7 even without having to run in XP compatibility mode.
Or if you have the installation disks for XP (if it was an OEM install, may have some issues there), you can do the reverse of the above and run XP in a VM and thus don't have to worry about it.
