Window Graphics Pricing
aubreycocklin
Hello All.
I've got a request for some window graphics...no cutting needed. Just installation of translucent vinyl to coat the entire window. They've got three windows, 45" wide x 115" high, all to be coated with translucent white. On one window only, I'll be cutting out a translucent red square, and cutting the white vinyl out where the square is to be placed. I'm coming up with some very high numbers, based on buying 3M by 48" x 10 yards (+3 additional yards) from Fellers. I just want to make sure that I'm in the ballpark...
Thanks for any input!! :)
ChiefBL
What range are you coming up with?
My Estimate software shows pricing at $213.00 each...Less after you apply some discounts for qty.
I'm new to the business, reading the board myself, comparing other quotes with my software.
aubreycocklin
By the time I've figured in buying the 48" vinyl in the 10 yd. and the 3 yd. increments (thus losing the discount for purchasing a whole roll...and I have no need to purchase the whole roll of 48" as I've only got a 30" plotter), I'm more around $650 per window...which seems high...but the $213 seems low to me...
signage
Aubrey you could buy the whole rolls and when you're done with this job cut them down too 30" and have 30" & 18" rolls to be used. Just a thought. Vinyl cost should be $7.25 your cost per linear foot for the white and $12.13 for the red! I come up with $217.78 each for materials the rest depends on your labor charge and time estimate. Hope this helps.
ovrcafnatd
I'm not sure, so someone correct me if wrong, but I thought it wasn't a good
idea to cover an entire window with vinyl. Don't you take the chance of the window cracking due to slight expansion and contraction rate diff. of the vinyl...having to do with temp. changes and such...even if it's cast it wants to shrink a bit.
Just something I thought was the case Aubrey.
Might want to check into that first....before covering the entire window (pretty large windows in this case too)
aubreycocklin
ok...yeah, the $650 was including labor and time...i'll have ot go back and see what my actual cost of materials was...how much would you mark it up? since there's no design or plotting involved?
does anyone know anything about why you shouldn't cover the whole window?
thanks!!!
Checkers
Hiya Aubrey,
Your price seems to be inline to me. If anything, it's a little low. I'm coming up with a price of $764 installed.
On a project like this, I would normally double my material costs ( think Fred referred to this as a Keystone Mark up) and add my labor and trip charge. The reason for doubling my material costs is because I'm using materials that I nomally would not stock.
Checkers
aubreycocklin
$764 per window, right?
And...that makes sense, because I wouldn't normally stock that material...
Thanks for all the help!!!
aubreycocklin
thanks!!!
Arlo Kalon 2.0
Back in the daze of signPAINTING, it was a rule that you run a strip of one inch masking tape around the edge of the window if you were painting the whole window. It was an issue of heat expansion. I actually saw several very large plate glass windows that had been solidly coated yellow crack in half! In fact, the guy who did them lives in this town and it cost him (actually his employer) a veritable fortune to replace six windows I think it was.
Arlo Kalon 2.0
BTW... if that avatar is YOUR pic... ya wanna job?
(okay, okay - don't everyone jump my case for that! If yer a guy, you were thinkin' the same thing!)
aubreycocklin
of course it's MY picture!! and thanks ;)
so...those windows you're talking about...were they painted or vinyl? and does the same hold true for coating out an entire window in vinyl? does leaving an inch border eliminate this issue?
Arlo Kalon 2.0
The windows that cracked were painted with a roller... I have no idea for a fact if vinyl would present the same issue. I, however, would never take the chance of not leaving the inch of open space around the window. That is, unless I explained the possibility to the customer and made them SIGN OFF on a statement that they were told about it and THEY okayed solid coverage anyway.
Checkers
My price would be for all 3 windows.
You can pick up a 10 yd roll of translucent vinyl for a little as $150 for oracal or avery 6 yr or about $220 for 3M. Double your mateial cost and add your time for labor.
I'm estimating that it would take me about 6 hours to complete this job. I would cut the panels to size before I arrived at the site and apply them wet, without using transfer tape. I would put a hinge across the top and use a foam squeege to complete the application. The install should take no more than an hour per window which leaves me 3 hours for travel and prep time. To make the application go a little easier, I would leave anywhere from a half to a full inch border around the edges.
I've heard stories about the glass breaking when vinyl or painted stripes were applied in a narrow area across an entire pane of glass. But I've never had or seen it happen.
Checkers
