Need Help Window Perf keeps coming up
DannySanti
I am using some ultra-flex 70/30 window perf and I keep having issues where it wants to come up in the corners and also tries to flip back over on some of the short edges the whole way. I also put on edge tape. I am not sure if it's an ink issue oversaturation because I've done several with white edges and they seem to work really well but in any case I need to do edge to edge printing and I need something that will stick to the window. Any suggestions would be greatly appreciated.
DL Signs
Never go against the family
Make sure the glass edges are super clean, use blades to get off anything you can't see. All the stuff they use to set the glass (silicone, lubricants, etc), you really can't get it all cleaned off tight to the edge without damaging the window seal, nor can you really see the residue. Trimming the perf or keeping edge tape back 1/8 inch or so from the seals usually does the trick, and it isn't really noticeable, or at least it's a lot better than watching it fail. If you're cut back from the edge and it's still lifting, you might need a better cleaning, or use a bead of primer around the perimeter too. Try some experimental pieces to see if that works.
Also, don't lay too quick after printing edge to edge, and don't go crazy on the saturation. Solvents from inks can penetrate through to the adhesive, make sure they're fully cured before laying.
That's about all I got.
Reactions: 1 users
MarkSnelling
Did you laminate the perf? If only two sides are curling up and you laminated, then definitely too much tension on the laminator. I'd also wait half a day minimum before cutting flush to the ink.
unmateria
i am curious.
why roll image out?
just during the 2 days, or always?
Well, if u can cure it unrolled, is much better but if u cure it enrolled, with much ink, is better that way. Anyway u will feel the vinyl... If its properly cured, it should be like a sheet of paper, bending only in one direction and if its not cured is like blandibloop (bends in all directions). Dont take the 2 days as a máximum, but a minimum ;)
  • Hilarious!
Reactions: 2 users
DannySanti
I do not laminate my window perf and I do usually roll the ink on the outside. What I'm wondering is if there's a better brand to use that has better adhesion
TEN
DannySanti - It is unusual that the perf is lifting if edge tape was applied? How much was the perf trimmed back from the edges? Is it 3M 8914 tape? We have never had edges lift once we started using edge seal tape on perf.
Reactions: 1 users
jfiscus
Rap Master
Probably just super crappy perf. Ultraflex isn't really known for quality materials.
Get hold of ContraVision and see if they'll send you a sample roll of their perf to try out. We have not had any issues from their products (as always; use the appropriate material for the job, as they have different material grades).
unmateria
I dont remember the name hahaha i think is called slime now, but when i was a kid, that was the name in spain at least hahaha
Modern Ink Signs
Just a word of advise when asking for help on something like this.
Images
What type of printer/ink (eco, latex)
What material(s) used (vinyl and lam)
The more info given those that offer help/advise/etc can be more educated to your problem.
It would be like taking your car to your mechanic and saying I’ve got a rattle. As opposed to there is a rattle in the front right when I turn left at slow speeds.
