Window perf + UV print
10sacer
Printed several large 42x61 inch panels with Clear Focus window perf on our UV printer and the ink that has dried in the "holes" is not releasing when we peel the backer off. Short of spending hours blowing out the holes with an air gun, anyone got any suggestions on how to get the negative holes cleared so the perf views properly.
h82loose
Cant help with this job. They do have perf for UV. Has layer between liner and vinyl to allow ink through holes. I have not tried it but saw it at ISA. Asian material
MikePro
yeah, don't print on perf with UV.... print your artwork on clear with the perf. pattern subtracted from the image
BigfishDM
You can use my perf, it has a double release liner so the ink will not stay in the holes. Its only $0.41 a sq.ft also. I had this made just for that reason.
10sacer
Big Fish - please PM me with that material info.
FYI - i took a pressure washer to it on really low setting with a fan pattern and it knocked out all the fill ins.
