Wrapping corners
canavans
What is the best way to wrap the corners of a spoiler. It is slightly curved surface but goes almost to a point at the ends. Any tips?
same way you wrap the inside of a wheel-well... you don't.
heat and stretch it as far as you can to the underside, trim to make it look clean. seperate tile/patch for the underside if you're worried about what it will look like when the trunk opens.
PhatWall
actually if you put some double sided sticky tape along the inside of the wheel well then you can do th inside of the part of the car
